Old 06-03-2003, 07:04 PM
Default Everett-Morrison radiator
Since E-M isn't open for business yet, can any of you E-M owners tell what radiator you used? The manual I have says a Modine #738 is the one to use, but I'm told by the dealer I called that there is no such model number. I'd like an aluminum one but don't no what size to ask for.
I could like some advise on this from you guys, I have a 408 stroker for an engine.
Steve
Old 06-03-2003, 08:02 PM
My friend just bought a radiator for his EM....fits like a glove. I will get in touch with him at let you know what he bought.
Roger
Old 06-03-2003, 08:45 PM
Cobra Make, Engine: Former Everett-Morrison,428SCJ
You want to be sure that the radiator will fit YOUR E-M. I've got an older frame (1985 I think) with the Mustang II front end, and I've only got 23" between the rails. The later frames are not the same, and it may also depend on which front suspension you have. Measure before you order, don't trust their manual!
Good luck!
Jon
Old 06-03-2003, 09:55 PM
Thanks guys!
I really appreciate the help in this. I guess I should have finished the car before E-M went under or whatever has happened.
Steve
Old 06-03-2003, 10:19 PM
6T5 Cbra's Avatar
Cobra Make, Engine: Everett-Morrison, FE 428
I'm running a 428 in my EM and use a 'Ron Davis' 2 core aluminum radiator (28" x 19"). This is the max width that I can run between the frame rails. Don't know what EM recommends but I believe it's in the 25-26" width range.
Gene
Old 06-03-2003, 10:34 PM
Hotfingrs's Avatar
When I ordered my radiator from EM a couple of years ago, they sent me a Griffin...don't remember the number though, can measure the size if you're interested
Jack
XSSIVE .....
Old 06-04-2003, 04:05 AM
larryar's Avatar
Cobra Make, Engine: CACC Member. Power Performance, 2X4's, 428
Default Radiator
Contact Fred Gimbel at Autovision 717-382-4312. He can supply any part for an Everett-Morrison. He was there dealer and now has second sourced all the parts necessay to build one from scratch.
Big Blocks Rock!
Old 06-04-2003, 03:46 PM
tim tim is offline
Cobra Make, Engine: Everett-Morrison, Boss 351 w/ TKO 5 speed, 94 vette suspension
Griffin was making the radiators to EM specifications. You should be able to contact Griffin and get a radiator from them. The next question will be, Do you have the radiator mounting hardware?
Tim
Old 06-04-2003, 04:49 PM
427sharpe's Avatar
I have a Griffin now, but the original unit that EM spec'd in the car was one from a 1967 Skylark w/ a big block (403??). I had no trouble but wanted a little bit more heat transfer, so went aluminum. If you are going to try the older style radiator, I would ask the radiator company for the dimensions and make sure that it will fit FIRST, as the frames have changed over the years. If you don't have the radiator mounting hardware, post here and I will measure mine and get you some dimensions so you can make one. It is pretty basic, so you should not have too much trouble.
Old 06-09-2003, 11:42 AM
Default Brackets
I managed to get a part number and order it from Summit Racing, but I don't have mounting brackets. I may try calling Fred Gimbel and see if he can hook me up or I'm going to have to make them myself.
Steve
