Old 06-29-2003, 04:57 AM
Question Is size important
I am running a 302 with a T5 trans,the clutch master cylinder is a 7/8 dia. Tilton.
Most slave cylinders seem to be 1" dia. will this present a problem in the feel of the clutch pedal?
If anybody has any suggestions on a pusher cylinder(part #)it would be greatly appreciated.
I realize there are complete slave cylinder kits
out there but with the exchange on the Canadian
dollar and shipping/brokerage fees they become
very expensive for us neighbors to the north.
Thanks again.
glenn b
sparky
Old 06-30-2003, 07:44 AM
Mr.Fixit's Avatar
Smaller master = less pressure needed with your left foot. Problem is you will lose travel at the slave because of less volume of fluid being moved by the master. Worst case, you need a smaller bore slave cylinder to gain travel at your TO bearing.
