Old 07-23-2003, 08:15 PM
Default brake noise
I have installed rear discs (92 mustang) on roadster. Since
then, pedal stays soft, and noise at low speeds, almost seems
to be from right front wheel. Have replaced hoses, pads, and
dont know what else to do. on lift, can turn rear wheels and
groaning sounds comes from brakes???
Has anyone had this happen, and have any suggestions for
what to try next?
bob
GHOST
Old 07-25-2003, 12:06 AM
Monster's Avatar
Cobra Make, Engine: Arntz/Bennett, FE with lots of shinny parts that make it go fast
What condition were the "new" '92 calipers in that you put on the car? Did you disassemble and clean them before installing them? It's possible that you have a couple of things going on. If by soft you mean "spongy" that could be air in the lines. The noise could be caused by a piston in the caliper sticking.
good luck,
Mike "monster"
Old 07-25-2003, 04:18 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Sticking is very noticable if the car pulls to one side or the other when the brakes are applied.
Sounds like air in the lines. The bleeder on the caliper may actually be in a position where not all the air is bled ( seen this before ).
What does this noise sound like?
Old 07-25-2003, 05:02 PM
the pads may not have been cleaned well, they were in plastic,
so I just "assumed" they were clean. I have bled way too many times, but who knows? the car does not pull either side, and the
noise is a low groan, not metallic, but moan and groan???
Thanks both of you!
GHOST
