SUPPORT OUR SPONSOR
Old 08-04-2003, 03:09 PM
Club Cobra Member
Cobra Make, Engine: SPF #1507 427 Dart Block Windsor
Another possible solution: Make some locating studs from bolts the same diameter as the pan bolts and about 3" long. Cut the heads off and round the cut-off ends. Clean everything thoroughly, then slide the pan assembly up onto the motor over these locating studs, hold it lightly in place with your bottle jack and replace the pan bolts. Worth a try to avoid pulling the motor.
Good luck.
Display Modes
HTML code is On
