February 2026
Old 09-25-2003, 10:30 AM
rdorman's Avatar
Renegade Nuns on Wheels
Default 351 Cleveland timing
Any one know what ignition timing would be a good starting point for an open chamber 4V cleveland motor?
OhioCobraClub.com
LondonCobraShow.com
Old 09-25-2003, 10:59 AM
Cobra Make, Engine: Unique 289FIA
Rick: I was timing it around 10 degrees. that should be a good starting point..RR
Old 09-25-2003, 11:24 AM
Woodz428's Avatar
Arrow
I run about 12 initial and have the advance come in quick, it adds a little bottom end .
WDZ
Old 09-25-2003, 03:08 PM
rdorman's Avatar
Sorry guys! I should have asked what I was looking for. What TOTAL timing.
OhioCobraClub.com
LondonCobraShow.com
Old 09-25-2003, 04:07 PM
ELGEE's Avatar
Cobra Make, Engine: Midstates 427SC-351C- 24 years old !!!!!
Hi-
I starting at 14 initial ,36 total---MSD BILLET ,mechanical advance.
No problems -redlining at 7500.Screams all the way to the top.
HOWEVER- all depends on cam,carb,manifold,compression,bottom end setup(2 bolt,4 bolt),bearing clearances,everything that makes a complete package--all trial and error on my part to get
where I am now.(351C,4V,open chambers)
LARRY G.
Old 09-25-2003, 04:36 PM
Woodz428's Avatar
Arrow
I'm running 38 total and it's in a '70 Boss 302, which is considerably heavier than a Cobra.
WDZ
Old 09-25-2003, 05:44 PM
kountzecobra's Avatar
Run as much timing as your engine can stand. Trial and error. Keep advancing the timing until it pings under acceleration, then back off just enough to stop the pinging. It doesn't really matter what the numbers are, just keep it for future reference. These Clevelands like as much timing as you can safely screw into them.
David Shelton
Lone Star Gashole!
Old 09-29-2003, 10:12 AM
rdorman's Avatar
Default Thanks
I bumped it up to about 36. It seems much happier!
OhioCobraClub.com
LondonCobraShow.com
