SUPPORT OUR SPONSOR
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 10-11-2003, 06:36 PM
Cobra Make, Engine: Ford 302HO
Default Original Gas tank?
This question is not for everybody but I would like to know if anyone has the demensions of the original gas tank for the 289? With the body so close to the ground and with the spare tire in the trunk-how did they fit the gas tank in there? Next is where did they mount the fuel pumps?-inside the trunk well or outside in between the frame rails? I have tried a search and have flipped through all my books but it seems all that they show is the spare tire and no tank-- so I am wondering what shape? the tank was. Thanks for all the help. Rich
Old 10-11-2003, 07:01 PM
David Kirkham's Avatar
Original Shelby Owner
Smile
The 289 street tank was mounted right behind the driver under the rear cowl area. If you were to look into the trunk--look up above the spare tire tray and you will see an aluminum interior panel. Behind that panel, (and under the rear cowl), is the gas tank.
The FIA cars used the same tank, along with an extra tank which mounted right behind the 1st tank. That tank is clearly visible on FIA cars.
David
Old 10-11-2003, 07:04 PM
ST's Avatar
ST ST is offline
Cobra Make, Engine: Kirkham#182/Shelby 496c.i.
Here's CSX2259:
http://www.csxinfo.net/289cobra/csx2...s/DSC01661.JPG
"You can NEVER teach a pig to sing! You'd just be wasting your time and annoying the pig!"
Old 10-11-2003, 08:27 PM
Thanks for the info David, maybe one day I will be able to have one of yours but right now I have to search and then build it myself.
St- thanks for the link, that helps out a lot.
Rich
HTML code is On
