Old 11-07-2003, 04:32 AM
BlueRooster's Avatar
Cobra Make, Engine: SPF #623 460/4x2
Default Water pump bolts
During a visual inspection the other day I noticed that some of the bottom bolts on my water pump are oxidizing.
Question:
Can I take one bolt out, clean it up, and tighten it back up without disrupting the existing gasket seal?
Is there a type of bolt/metal that would prevent this from happening again?
Is there a torque spec for a water pump bolt?
Old 11-07-2003, 06:46 AM
Chaplin's Avatar
BR-
1. Depending on which bolt it is, you should be able to.
2. A stainless steel bolt would do the trick.
3. I'm sure there is, but I don't know what it is. Before taking it off, put a torque wrench on it and see what it's currently torqued to and just re-install to the same torque.
Or you could just take a little steel wool and wd-40 and clean it up.
Replica is not a dirty word.
