SUPPORT OUR SPONSOR
Old 11-04-2003, 01:13 PM
Tongue Pirate's Avatar
Default Body work side vent holes.....
I'm to the point of working on the body where the side vents are. Does anyone have a good closeup pic of this area? Most importantly= the holes are cut as if they used some type of 90 deg saw so the cut is clean & square. I'm curious if this edge should be rounded? or should I just clean it up & paint?
Hyde D. Baker
Old 11-07-2003, 07:58 AM
Beuller? Anyone?
Hyde D. Baker
Old 11-07-2003, 08:21 AM
computerworks's Avatar
Here is a closeup of the cutout on a Kirkham...
...the corners are rounded...
Old 11-07-2003, 08:30 AM
Fox's Avatar
Fox Fox is offline
Cobra Make, Engine: 302 done, CSX289 comp body, leaf spring chassis to original specs...
"Ferris, your my hero" -Cameron
So you been broken and you been hurt, Show me somebody who ain't
Yeah I know I ain't nobody's bargain, But hell a little touchup, and some paint...
Old 11-07-2003, 09:40 AM
Thank you! That helps a lot I've got a long weekend of bodywork ahead of me, hope to get a lot done.
Hyde D. Baker
Old 11-07-2003, 02:35 PM
cobrajeff's Avatar
Default Fender vent cut-outs
Hyde -
I went to a great deal of trouble to hide the thickness of the fiberglass body in this area. Using a die-grinder and various "tootsie" rolls, I ground and tapered this area from the inside of the body for about an inch around the opening.
I actually glued a piece of thin aluminum to the inside of the fender so the backside of the fender appears to be aluminum while looking into the engine compartment. I also glued some foil insulating material to the inside of the fender near the exhaust cut-outs, to insulate the paint finish from the heat of the headers where they pass through the body (I've seen a lot of cars with blistered paint in this area).
regards,
Jeff Burgy
CobraJeff
ERA P 202
Old 11-07-2003, 02:51 PM
Jeff, I figured you'ld come through eventually in that way over done fashion. Thanks! Again, your car is nothing short of amazing!
Hyde D. Baker
HTML code is On
