SUPPORT OUR SPONSOR
Old 01-13-2004, 10:50 AM
Default Jag rear end help
I'm in the middle of shortening and rebuilding my Jaguar DANA 44 rear end, just a couple of quick questions.
1. Is it true that you can use Chevy u-joints? If so, what part numbers are available?
2. The Jag rear end that I aquired has no u-joint on the third member, there is a flange with 4 bolt holes which looks like something gets bolted to it which has provisions for u-joints.
Does this come from another manufacturer or can I buy it new?
Thanks in advance for your help.
Rick
Old 01-13-2004, 02:23 PM
rdorman's Avatar
Renegade Nuns on Wheels
The half shaft do use a typical chevy u-joint. Look for Dana Spicer 5-160X. Not sure where you aquire the 'other part'. Try Jag or a wrecking yard. Do a search in google, I am sure you will turn up something!
Rick
OhioCobraClub.com
LondonCobraShow.com
Old 01-13-2004, 02:30 PM
Cobra Make, Engine: Unique 289FIA / SA 351W / a truly glorious machine
There is a Jag site CWI, possibly that lists and supplies all of these parts...
Do a Google search and it will turn you to the site...
Old 01-13-2004, 03:30 PM
1GR8BOSS,
We use Presion joints #330. I heard CWI quit doing Jag rear ends.
Poorboy
Old 01-13-2004, 07:33 PM
stevehaygood's Avatar
Cobra Make, Engine: B&B 427 body and building my own chassis. Modifying a Jaguar front irs and a Dana 44 in a 4 bar set up in the rear. 351W/408 Stroker I am building myself, top loader 4 speed..Dana 44 rear w/ 4 link
Send a message via Yahoo to stevehaygood
GR8BOSS,
www.jaglovers.org has links to anything having to do with jags
Also the Haynes manual is pretty good.
I am fabricating my own chassis and am about to put on the rear clip. How wide is the track you are "trimming the rear to??
Semper Fi!
Bigfoot.
Mike Co. 3/5
1st Marine Division
"The Nam", 1967
Grunt infantry
Old 01-14-2004, 02:58 PM
jschiller's Avatar
Cobra Make, Engine: Past owner ERA 146, ERA 694 in progress, 428 CJ, toploader
1GR8BOSS
I think the item you are looking for is a flange yoke, spicer part no. 2-2-459. It adapts the round flange on the rear's pinion to a u-joint, specifically a spicer 5-153X. Then you will need a spicer 2-28-437 welded on the rear of the driveshaft to mate up to the ujoint. Hope this helps.
Old 01-15-2004, 05:38 AM
Really appreciate all of the information as it is the one I am specifically interested in. It is very satisfying knowing that I can rely on other Club members to come through with the information I need to build my car.
Thanks once again,
Rick
P.S. to Mr. stevehaygood.... I am looking at 52'' to 54''wide.
Old 01-15-2004, 04:14 PM
1GR8BOSS,
GREAT THANKS VERY MUCH!!! SEND SOME PICS AS YOU PROGRESS!!
Semper Fi!
Bigfoot.
Mike Co. 3/5
1st Marine Division
"The Nam", 1967
Grunt infantry
HTML code is On
