SUPPORT OUR SPONSOR
Old 01-21-2004, 09:58 PM
G.R.'s Avatar
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Default Lucas Wiper
I've searched the archives on this and couldn't find my answer.
I have a Lucas setup--the wipers are typical Cobra style. Wired only to an on/off toggle, low speed--the switching and electrical I can handle, there is a hi/low/park connection on the motor. Plan on using a Lucas wiper switch.
Problem----the wiper works fine with the blades off, full sweep of the armature--put the blades on then it binds and only moves the
blades 2-3", doesn't blow a fuse, just sounds as if something is slipping and not overcoming the tension of the wiper arms against the glass.
Any Ideas?
Also how do you disconnect the motor from the cable? loosened the bolt to expose the worm cable but couldn't get anything to come loose?
This little sucker has got me confused
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
Old 01-22-2004, 01:54 AM
CobraDan's Avatar
Old 01-22-2004, 02:03 AM
Cobra Make, Engine: Unique FIA
Smile
Gary,
Here is what is going on inside the motor and lucas switch. Hope it helps you understand how it works. Unless you use two relays to control the motor correctly, the lucas switch is the best way to go
Steve
All my ex's live in Texas
Old 01-22-2004, 08:05 AM
PatBuckley's Avatar
GR-
From the sound of it you are having a mechanical, not electrical, problem. Perhaps where the cable goes by the transmissions isn't tight enough?
As to removing the cable from the motor, I gave up. I am not using wipers so I was going to take the cable off for storage....ended up storing it in one piece.
Old 01-22-2004, 06:29 PM
G.R.'s Avatar
It is not an electrical problem--Today I switched the lead to the high position--same thing--works fine without the blades--put the blades on it binds or slips--like I said before the electical is not a problem for me.
As Pat said it is probably mechanical? I can put the blades on and put minor pressure on them to "help" them complete the cycle--without the "help"(gentle pressure on the blade arm)2-3" movement on it's own.
The guide rods for the wipers are straight from the motor, no kinks, curves, etc. .
My thought is the cam gear on the motor may be worn and slipping when under pressure from the tension of the blade arms
Only thing is I can not figure out how to get the motor separated from the "worm drive" cable so I can open up the motor to check the cam gear.
Since I live in WA wipers would be beneficial.
Old 01-22-2004, 08:50 PM
Double Venom's Avatar
Gary,
You have to take the plate off to get to the drive gear. Once the plate is off you can then pull the cable loose.
Send it...no Bring it to me, I'll fix it for ya. Want to install a boiler while you're here?
DV.....Hey, they're calling for a high of 6 degrees tonight!
Old 01-23-2004, 02:02 AM
Ed,
6 degrees? Better you than me pal.
Steve
Old 01-23-2004, 04:49 AM
hog hog is offline
Cobra Make, Engine: Shell Valley 351W Tremec 2004 Cobra SVT Convertible
I wonder where COBRADAN got the relay layout?????
hog
Old 01-23-2004, 06:56 AM
Smile
Hog,
He may have gotten it from Petek check out this link:
http://www.birch.net/~petek/cobra/99/aug1.htm
Steve
HTML code is On
