SUPPORT OUR SPONSOR
Old 01-31-2004, 06:53 PM
Bruce Edwards's Avatar
Cobra Make, Engine: Hunter with a 4.6 supercharged
Ron,
You will need a flywheel, piolt bearing, bellhousing for a Toploader if you go that way or if you go the Tremic 5 speed route a different one for that, a clutch set, clutch fork, cable set or if you want slave & master along with a clutch pedal set up that will work with the set you have in the car now. You will probably have to build a new shaft as the input may not work with the manual trans, and a shifter set up for the top loader, or a shifter handle for the 5 speed.
We use the smaller 302 flywheel as it cuts down on weight so the engine spins up a bit faster. Remember you have to match the flywheel to the bell housing.
The 8 inch will not hold up with a 351 and stick. You will need to swap it to a 9 or something as strong. The 8.8 is a bit soft for anything bigger than a 302, my opinion, the axles have a bad habit of twisting off. Yes you can get better axles but for all the work why not just put in a 9 and be done with it.
That and a bit of time you got it made!
Bruce Edwards
Gemini Motorcars Inc.
Bruce Edwards
http://home.bellsouth.net/p/PWP-GeminiMotorcars
HTML code is On
