Old 02-22-2004, 07:37 PM
Cobra Make, Engine: 2000 JOHNEX 427/351
Default Total Timing For 427/351
Have a 427 Windsor and don't the the cam grind except that it is a hyraulic roller. Was wondering what total time and initial time should this size engine be running?
Any information would be appreciated.
Old 02-22-2004, 07:42 PM
probably about 32 degrees
Old 02-25-2004, 06:40 PM
Cobra Make, Engine: I drive and test my customers
In our 427 Windsors we set initial timing at @14 to 16 deg. and total @ around 33 to 34 deg. Hope this helps
Eric H.@ Performance Engineering
Old 02-25-2004, 06:49 PM
Thanks for the response, it does help. I have timed the engine 17 initial and 33 total. Haven't road tested yet, will let you know.
ken
Old 02-25-2004, 07:49 PM
Cobra Make, Engine: BDR 89 KEITH CRAFT ALL ALUMINUM 427 WINDSOR
Don't know what the initial timing is set, but Keith has got mine set at 38 degrees total. 427 stroker, aluminum block, aluminum AFR 225 heads, 10.5 compression ratio, pump gas motor
DON
Old 02-26-2004, 05:20 PM
Mr.Fixit's Avatar
it depends on the motor, 30-34 is the expected range, with many guys running about 34. We used to do some really hot small blocks that only liked 30 total.
