SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 02-24-2004, 07:27 PM
joea's Avatar
Cobra Make, Engine: ERA #676, 428SCJ (2x4), TKOII
Question Engine Sensors
I'm putting the finishing touches on my engine and I am wondering about sensors...Oil Pressure, Temp, etc... Which ones do I need to buy, where on the engine do they go?
I figure the oil temp guage probably screws into my oilpan. Where does oil pressure go? engine temp?
"There are 10 types of people out there....the ones that understand binary and the zeros that don't."
Old 02-24-2004, 08:56 PM
Bruce Edwards's Avatar
Cobra Make, Engine: Hunter with a 4.6 supercharged
Joe,
What engine? Ford small block picks up on the left front just behind the timing cover and just above the pan for the oil pressure and in the intake manifold for the water temp. Small block Chevy can be picked up in a few palces for oil pressure rear of the block front of the block but water is in the head or intake.
Hope that helps.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
Old 02-24-2004, 08:59 PM
joea's Avatar
Big Block - FE
Old 02-24-2004, 09:05 PM
Joe,
Top of oil filter housing for oil pressure and should have a hole just behind the distributor for the water.
Bruce Edwards
Old 02-24-2004, 11:27 PM
joea's Avatar
You think NAPA has these?
Old 02-25-2004, 04:52 AM
joe,
The sensors have to match your gauge set. If you are talking about an engine in your old Ford with stock gauges yes NAPA would carry them.
If this is an engine for a Cobra kit the gauges you got for the car should have come with sensors.
Bruce Edwards
Old 02-25-2004, 05:23 AM
All the sensors come with the gages. You don't need to buy anything.
You'll need a place on the block or oil filter housing for a 1/8" pipe tap for the oil pressure gage, and 1/2" female pipe threads in the intake manifold and oil pan for the water and oil temperature probes.
That's it.
Old 02-25-2004, 09:25 AM
joea's Avatar
perfect ... thanks!
Old 02-25-2004, 09:52 AM
Chaplin's Avatar
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Joe-
One piece of advice which I picked up here. On the oil temp sensor, do not use teflon tape on the threads, it may prevent a proper ground and cause irratic readings. Get some of the teflon paste instead.
Also, if you are using the remote oil filter, the block adapter has a port built into it to hook up the pressure gauge.
Replica is not a dirty word.
Old 02-25-2004, 10:52 AM
joea's Avatar
Thanks Chappie...I have not used any teflon tape on my engine at all. I'm sticking to the tube stuff. My fileter adapter has an 1/8" female thread on top for the pressure sender
HTML code is On
