SUPPORT OUR SPONSOR
February 2026
Old 02-27-2004, 05:54 AM
Cobra Make, Engine: considering a kit
Send a message via Yahoo to ssgstinger
Default 429/460 building
can I use 460 pistons in a 429? trying to lower compression so I can run pump gas. please help.....
ssgstinger
Old 02-27-2004, 09:40 PM
Cobra Make, Engine: I drive and test my customers
The best way to lower the compression is to get a dished piston from SRP (A division of JE pistons). They can sell you a good forged unit for the head you are running, and it much stronger than stock. Hope this helps
Eric H.@ Performance Engineering
Old 02-27-2004, 10:35 PM
HighPlainsDrifter's Avatar
Cobra Make, Engine: F5 Roadster
Arrow
Hi,
An easy way to lower compression is to get later heads. You probably have heads with 72 cc chambers, later heads are 92 , 95 or 97 cc's. This will lower compression between 1 and 1.8 points, depending on your starting point.
I run 98 cc open chamber heads and a flat top piston, this will give the best flame travel.
Perry.
Display Modes
HTML code is On
