Old 03-09-2004, 09:06 AM
Cobra Make, Engine: ffr2497--302efi
Default what thermostat to use?
hey guys,i have a 302 efi in my ffr--and need to replace the
thermostat--what degree range do you recommend--
i live in n.y--160 --180--or 195 degree thermostat
dave
i will have one soon!
i have one now.
Old 03-09-2004, 11:45 AM
Cobra Make, Engine: ERA / nascar side oiler
I use a 195 in cooler temps , I have been warned that I need to keep my block at 180 to keep oil on the cylinder walls . I have tried a 180 but my aluminum radiator / 16 fan makes me use a 195 .
You may need to try out a few , then get a good one , some are made to get stuck in the open position
Old 03-09-2004, 01:30 PM
TonyMadrid's Avatar
Cobra Make, Engine: A&C 351W, C4
Default Most small block ...
Most small blocks run at optimum performance just around 200 degrees. With that said, it would seem that you should go with the 195 Deg thermo. However, I believe most small blockers are using a 180 Degree thermo; thats what I use.
Old 03-09-2004, 02:23 PM
DAVID GAGNARD's Avatar
I believe most if not all 302 efi's came with a 195 thermostat,I'd stick with that...... For a carbed engine,I run 180's....
DAVID GAGNARD
Old 03-09-2004, 04:59 PM
thanks guys for the info--i have a aluminum radiator also--but i
control the fan operation.i will install a thermoswitch-to
control the fans to be safe
dave
i have one now.
