SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 03-22-2004, 10:50 AM
zipzip's Avatar
Cobra Make, Engine: Midstates work in progress, personally built 302
Default lower radiator hose connection
I was wondering if anyone has a slick way to connect a lower radiator hose.
I was thinking of trying to use some AN fittings and hoses to dress the whole thing up, but am running against some part availability dilemmas. I was considering welding on an AN male weld bung to the lower connection, then running hose from there. The trouble is that the connection is 1-3/4 ID (-24 AN) and I can get a weld bung, but no aluminum hose connections! I'd hate to reduce the thing down to 1" which is where I found most of the fittings commonly available. I also have a couple of tight bends to go around the frame and steering rack, then back up into the pump.
Any ideas, pics, part #'s?
You might be a redneck if you think the National Anthem ends with "...Gentlemen, start your engines."
Old 03-22-2004, 11:38 AM
Rick Parker's Avatar
I would stay away from the large AN fittings. They do not allow for much compliance (flexability), and they are very pricey. I chose to fabricate a "hose" from aluminum mandrel bends, ring the ends and attach it with 4" pieces of straight hose. By doing this I was able to route the hose through the front structure and around the steering rack without any rubbing at all. As a side benifit if the rubber hose ever needs replacing it will be easy to find replacement piece of hose. Check my gallery.
Rick
Rick
Old 03-22-2004, 01:53 PM
Cobra Make, Engine: #901 Superformance 427cid 540hp!
Default Cool flex hose
Take a look at "Cool-Flex" they are a CC advertiser, nice stuff!
"This year Ferrari's Ass Is Mine"
HTML code is On
