SUPPORT OUR SPONSOR
Old 04-01-2004, 05:12 PM
Send a message via MSN to CowtownCobra
Default Backfire on one side
Car is running great, but recently it has developed a backfire on the left side (none from the right). Letting off big time leads to a big pop, while normal slow downs lead to mutiple smaller pops. It didn't use to do this. What do I check for, fouled plug, bad plug wire, or what. I'm clueless...
Have hydraulic lifters so I don't think a valve is sticking open.
Ideas?
Old 04-01-2004, 05:14 PM
Tony Radford's Avatar
Cobra Make, Engine: Unique 427 SC, Southern Automotive 427W Stroker
Leak between header and head on that side.
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
Old 04-01-2004, 05:15 PM
392cobra's Avatar
6th Generation Texan
I take it you mean the exhaust.
Sounds like a bad gasket where the sidepipes/headers are bolted together.
Old 04-01-2004, 08:03 PM
G.R.'s Avatar
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Post
I've experienced the same thing, replaced my exhaust header gaskets(they are not leaking) and the header to exhaust pipe gaskets. Things were fine for awhile, then the backfire started again, turned out that it was from the header/pipe fitting, again, same side, blew out the gasket, replaced it once again.
It is slowly starting to leak again, sort of pops, especially when backing down. I'm sure it'll start the "k-pow" again in a short time.
I wish I had an answer but I've tried darn near every header gasket and combination, maybe my old pipes/connectors are just getting worn out.
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
Old 04-01-2004, 08:11 PM
joea's Avatar
Cobra Make, Engine: ERA #676, 428SCJ (2x4), TKOII
Maybe this will help...
http://faq.f650.com/FAQs/BackfiringFAQ.htm
"There are 10 types of people out there....the ones that understand binary and the zeros that don't."
Old 04-02-2004, 01:24 AM
Cobra Make, Engine: Almac Cobra 427R
I had the same thing happen - and it was caused by the tyre!
What happened was the tyre went soft, I understeered out of a sweeper at the race track, and hit the sidepipe on the ripple strip! Of course - it did make the manifold leak, but the tyre sounded like a better story.
Old 04-02-2004, 04:12 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Dave, Sounds like you might have a too lean condition.
I can not remember if you have a carb or FI, but what you can do is sweeten the mixture at the idle screws and see if the problem goes away.
It is common if you use the engine as a braking assistant and the engine revs are high enough to need more fule to sustain them. Yet your foot is completely off the pedal.
Simple way to check may be to give a little pedal as you slow down and see if the popping stops.
Just a thought. Are you still drinking with the cows?
Old 04-02-2004, 04:31 AM
Tony Aprile's Avatar
Cobra Make, Engine: SPF #1358 Silver/Black stripes 466 2X4
Default back fire on deceleration
Cowtown
I recently experienced this "LEAN"condition of popping or backfiring out of the left side pipe on deceleration and was given three places to look.
Intake manifold to cylinder head gasket
Header to cylinder head gasket
Sidepipe to header flange gasket
Well im my case the intake manifold gasket had disintergrated and moved out of shape to cause a vacuum leak at #5 cylinder. Replaced the intake gaskets and that was it.
Tony
Old 04-02-2004, 04:41 AM
Tom Wells's Avatar
Hello Cowtown Cobra,
All of my various exhaust orifices have leaked at one time or another causing backfires
If it's the collector, the best seal is this soft copper one (or equivalent from other vendors). If it's good enough for AA fuel dragsters, I reasoned, it's good enough for me
Copper collector gaskets
If it's the header gaskets (been there too - still there ) it takes more. Here's a gasket set:
Header Seals
and don't forget some sort of locking bolts:
Stage 8 locking header bolts
There are other brands of locking header bolts available.
And don't forget that there's still Permatex Red high temp sealant to try.
Does all this work? I don't know
It depends on vibration, temp, thickness of flanges, load on the joints (well all those pipes and stuff do sort of hang off the header flanges, don't they?) and intangibles.
It's a good idea to check the bolts pretty frequently too.
If you find a better way, please let the rest of us know
Regards,
Tom
Old 04-02-2004, 08:06 AM
Yah, I had to put the horses on the wagon, so the cows are all I've got left
Old 04-02-2004, 08:07 AM
Thanks all for the great advice. Thats what makes this website so great
Old 04-02-2004, 11:21 AM
trularin's Avatar
Member of the north
Well, I figured you gave up on the horses... They drink too much and get sloppy when intoxicated. LOL
Cows just slur their language and keep going.LOL
Hope you get this fixed.
Best wishes.
Old 04-02-2004, 11:22 AM
trularin's Avatar
Member of the north
Dave, did you get the new images of LoneStar's GT40?
Call Brian and take a look. You'll be workin a deal in no time.
Old 04-02-2004, 04:04 PM
Trularin,
I was out there the other day and saw all the photos in their albumn. It really turned out nice. Saw several bodies straight out of the mold. Lookin real good, great lines.
Now if I could only convince she-who-must-be-obeyed....
Old 04-04-2004, 06:16 AM
trularin's Avatar
Member of the north
Dave, got the same problem, but as it is unfolding, she has allowed me to bid on a two post lift for the barn.
This will make car care a lot more interesting.
Old 04-04-2004, 04:14 PM
Trularin, you lucky dog...
BTW, I replaced the exhaust gasket on the offending side, no more backfire! Thank to all.
Old 04-04-2004, 05:22 PM
I had the same thing early this year. After the car set for the winter I broke it out and noticed a backfire on the right side only. I had a loose plug wire. I wish they were all that easy....Check the simple stuff first.
SPF 1618
460, 552hp
+ Pro Shot Fogger system
(250hp shot)
802hp total
titanium\black stripes
Old 06-25-2010, 10:13 AM
Indy's Avatar
Cobra Make, Engine: Contemporary CCX 34010, FE 428
Default Thanks all -- cured!
Aha! I just changed my CCX's valve covers and got the one sided backfire. I was positive I had screwed up the valves somehow. But it was just a plug wire I accidentally pulled... thanks Spoony for the quick fix!!!!
--Indy
Old 06-25-2010, 11:14 AM
I wasnt so lucky and was getting a popping on accelration. Turned to be a bad spark plug. The ceramic was cracked. So dont always assume spark plug wires, spark plugs get damaged also.
Old 06-25-2010, 02:52 PM
ekrupa2's Avatar
Cobra Make, Engine: Former owner of SPF#2632
Had a similar backfire on deceleration...collector gaskets completely blown. So far I have been extremely happy with these...www.remflex.com.
Will switch my copper header gaskets with these someday too.
HTML code is On
