SUPPORT OUR SPONSOR
Old 04-06-2004, 10:01 PM
JEHOVAH's Avatar
Cobra Make, Engine: Dont have one yet, building it
Send a message via AIM to JEHOVAH
Default Carrera '03 engine: will it fit?
I have "inherited" a '03 Porsch Carrera engine block, i am wondering, will it fit on the same frame as a 428 or will i need to costom build it?
thanks for your responses
---JEHOVAH
I am not part of Jehovah's Witness, so don't ask.
Old 04-06-2004, 10:10 PM
J,
I don't know if it will fit or not but having previoulsy been into Porches I can tell you that will not be a cheap engine to put together if you only have a case. Also, what trans would you mate it up with?? If you head down that path I live just around the corner from you and would be very curious to see how it all goes together.
Good Luck, Steve
Old 04-06-2004, 10:13 PM
Is this engine going in the trunk?
Old 04-07-2004, 07:04 AM
PatBuckley's Avatar
It's a straight bolt in. This is a swap that is so obvious that it surprises me that NO ONE has ever even thought of doing it before.
Good luck and let us know how it goes!
Old 04-07-2004, 07:44 AM
JEHOVAH's Avatar
I have all of the trannie, the engine (with everything attached), and the chassis, how would i be able to put it into the trunk? i knmow thats how it is on the real porsche, but i wouldnt know how to do it on a '65 cobra. could somebody help me?
Old 04-07-2004, 08:02 AM
Well if you put it up front instead of back you could have a front wheel drive Cobra. Oh wait,,,,, steering.
OK, so put all that steering stuff in the back instead and steer from the rear!
Ernie
Old 04-07-2004, 08:11 AM
daltondavid's Avatar
Cobra Make, Engine: 1967 GT 350 #2264
Non FORD Powered COBRAS should not even be discussed, much less built!
www.saacforum.com
Old 04-07-2004, 08:43 AM
clayfoushee's Avatar
Cobra Make, Engine: Unique, 427SO, it runs
I hear the sound of yanking chains.
Clay
Old 04-07-2004, 09:23 AM
What about putting it in a Beck 550 Spyder?
Old 04-07-2004, 10:18 AM
joea's Avatar
Cobra Make, Engine: ERA #676, 428SCJ (2x4), TKOII
Personally I'm tired of people building Frankenstein Cobras. Don't ask for respect when you blatently disrespect the spirit of this car.
"There are 10 types of people out there....the ones that understand binary and the zeros that don't."
Old 04-07-2004, 10:32 AM
Back in Black's Avatar
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Default Get a second set of the drivetrain
One at each end for a 4 wheel drive high speed cobra ! Can I be in your will?
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
Old 04-07-2004, 10:34 AM
joea,,,, I fully concur!
Old 04-07-2004, 10:43 AM
I have a D6 Caterpillar motor with hydrostatic transmission...should I put the blade on the front of the car, or on the back?
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
HTML code is On
