SUPPORT OUR SPONSOR
Old 04-18-2004, 10:14 AM
Terry Stapley's Avatar
Cobra Make, Engine: Shell Valley, 418W, tremec 3550tko, 9" ford rear, 3.0 gear, silver/black
Default turn signal malfuction
I have an appointment to get my Cobra inspected Monday and all of a sudden my turn signals are acting up. They have worked perfectly before. The right turn when activated only blinks at the rear and the dash indicator does not do anything. The left turn does not work at all. The hazard lights when activated blink at all four corners as well as the dash indicator lights. I am getting power out of the trun signal switch to both sides but the wires run into a loom and I do not know where to look for the gremlins.
All the fuses are ok. HELP!!!
Terry
Old 04-21-2004, 10:35 PM
Monster's Avatar
Cobra Make, Engine: Arntz/Bennett, FE with lots of shinny parts that make it go fast
Terry,
check your grounds & connections. If things were working and now all of a sudden they are acting up , it sounds like a possible grounding problem.
good luck,
\Mike
Old 04-21-2004, 11:29 PM
I had a very similar problem in a late model pick-up. Turned out to be the round blinker relay in the fuse panel. A three dollar part. I just couldn't figure out why the blinkers wouldn't work but the flashers did. Anyway, for three bucks it's worth a look.
Old 04-22-2004, 06:36 PM
G.R.'s Avatar
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Would almost bet that it is a bad "flasher relay" a $3 fix. Had a similar problem in my truck a couple of years ago. Had similar symptoms. Started all at once, worked one day then not the next, yet you could hear the flasher click.
Might be loose grounds--maybe?
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
HTML code is On
