SUPPORT OUR SPONSOR
Old 04-18-2004, 04:58 PM
Cobra Make, Engine: BRM #20, Ford 302, Holley 600dp
Send a message via ICQ to ridelikehell
Default pulley bracket install on edelbrocks
motor is a ford 302:
i'm putting all the pulleys back together now and i'm on the big bracket that holds the alternator and tensioner...there's a big hole in the head that goes right through to the other side, in the head it's a 5/8" hole, but a 5/8" bolt will not fit through the hole in the bracket in order to thread into the head...i believe that hole is for some kind of emissions setup, which i don't need (kit car, no emissions) is it possible that maybe that hole was smaller on the stock head, and it's larger on the edelbrock...if so can I just drill out the bracket hole to 5/8" so it will fit?...i'm really confused here any help would be great!
Old 04-18-2004, 07:21 PM
Rick Parker's Avatar
Go to local Ford dealer, they will have the part you need which resembles a 1/2" long set screw with internal threads it is installed with a large screw driver, they have thread locker applied to keep them tight. They are used as you said to attach the EGR tubes to the cylinder heads.
Rick
Rick
Old 04-18-2004, 07:44 PM
will that act as a block for the holes? because i don't need/want to use them at all, and what excatly is it that I have to ask for, the stupid parts counter people never know anything unless they can imediatly pull it up on their screens...
thanks so far!
HTML code is On
