SUPPORT OUR SPONSOR
Old 04-21-2004, 11:24 AM
Cobra Make, Engine: built the molds and body composite construction
Default Non-releasing clutch
The setup I am running is a Richmond super T-10 to a small block. I have a Lakewood belhousing and I orginally had a Center Force Dual force clutch. This uses a diaphranm pressure plate with a Chevy disc since the spline is 26 not ten. I have tried numerous hydraulic throwout bearings and at present have a Howe bearing. I am getting good bearing movement and the pedal pressure is reasonable. The clutch refuses to release. I bought a Hays setup, diaphram with Chevy type disc. hoping this would cure the problem, it didn't. The disc is in the correct way as was the CenterForce. Still no release. Any ideas?
Bill K
Display Modes
HTML code is On
