Old 05-09-2004, 07:20 PM
Cobra Make, Engine: BRM #20, Ford 302, Holley 600dp
Send a message via ICQ to ridelikehell
Default MSD Blaster 2 setup help
Wow how is this for a noob question...
I can't figure out how the hell to get the blaster to attach to the coil wire (from the distributor)...theres like 5 different fittings in the coil package and the only contraption i can come up with is getting one of the rubber 90degree rubber things to come out the top of the coil, but even then theres nothing coming out the other side of the rubber boot (if that makes any sense)...SO if anyone could help me out with this one it would be great!
thanks in advance!
Old 05-10-2004, 05:54 AM
Clois Harlan's Avatar
What distributor are you working with?
On your Blaster Coil use the big black boot that will slip over the top of your coil. Slide your boot up your wire and install your brass terminal to your wire. If you are not using a new set or wires you may need to cut off you old distributor wire boot.
Sorry I can't be of more help.
Clois
"Let's roll"
"Be part of Something Good
