Old 05-16-2004, 05:28 PM
RPT RPT is offline
Default Check Engine light - Honda Civic 2000
My 200 Honda Civic has seen 60000+ miles. Just before I had the 60k service done, the check engine light came on, and spark plugs were a tad dirty. Honda Services said there is a problem with the sensor, and hence the check engine light; they would charge me 300+ to fix (something to do with re-setting the computer in the car). I balked, and continued driving. My milegae has been low (about 60-70 miles less). Recently, the check engine light went off by itself for a full gas tank, but came back on again next time I filled gas. Mileage just that time was normal, but went down soon as the light came on. So, what may be my problem?
Old 05-16-2004, 06:59 PM
Send a message via AIM to wrench
Did they tell you what the code was?
Age and knowledge don't always come together. Sometimes you just get the age...
Old 05-16-2004, 07:07 PM
Rick Parker's Avatar
Might be an Oxygen sensor in the exhaust that enrichens fuel mixture for certain conditions, perhaps it defaults to a rich setting when it begins to go bad and turns the light on?? I believe Autozone Parts Stores will diagnose or pull codes for you at no charge.
Old 05-16-2004, 08:07 PM
Jamo's Avatar
Super Moderator
Honda Civic...check engine light?
Send it to the crusher.
One down...
Jamo
Old 05-16-2004, 08:19 PM
Default O2 sensor
Might be the O2 sensor. I would buy the pricey genuine Honda sensor, I replaced my O2 sensor with a Bosh unit, it never worked right, was lucky enough to return it!
good luck.
Old 05-16-2004, 08:21 PM
kountzecobra's Avatar
I have to agree with Jamo.
"Honda.......... From the folks who brought us Pearl Harbor!"
David Shelton
Lone Star Gashole!
Old 05-16-2004, 08:26 PM
Jamo's Avatar
Super Moderator
Given the Alamo, I take it you don't like tacos?
Jamo
Old 05-16-2004, 08:41 PM
Be thankful the check engine light is still on. I can't get mine to start.
I went to www.clubhonda.com and I just dropped a bunch into a aero kic while I figure the rest out though.
Old 05-16-2004, 08:44 PM
Jamo's Avatar
Super Moderator
Two.
At this rate, it'll only take a couple of hundred years to get them all off the road.
Jamo
Old 05-17-2004, 04:15 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Just wait a little longer, maybe the "check engine light" will comeon all of them.
There is the realization that "Tora! Tora! Tora!" means nothing to some people these days.
Just my $0.02
Old 05-17-2004, 04:54 AM
Cobra Make, Engine: CLASSIC ROADSTERS 427 with a FORD 5.0 bored and stroked to 331cid, BRODIX alum heads, roller rockers, B303 cam.
The "check engine" light means the auto-self destruct sequence can not be aborted. Best take it to the crusher before it does some serious damage.
