Old 05-19-2004, 11:12 PM
Banned
jim
i'm getting off the subject a little here but what ever happened with your friend's 7000 series car with the brake problems? i'm interested in knowing what the problem turned out to be? thanks.......john
Old 05-20-2004, 05:30 AM
Cobra Make, Engine: ERA 289 FIA #2086, 302/320 HP, Dart heads, hydraulic
Ernie,
All the tests I suggested were while cranking, each to validate a specific leg of the circuit.
Old 05-20-2004, 07:23 AM
Ron61's Avatar
Post
Jim,
One more thing as mentioned above. A bad battery will stop a good one from craking the car if it has a bad cell or so. Higher voltage from the newer battery sees the bad one as a ground and won't go through. So if you decide to try it without removing the old battery first, disconnect it. I carry one of the small portable jumper units in my cars and they work great.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 05-20-2004, 08:45 AM
sharpe 1's Avatar
Cobra Make, Engine: Midstates,SBF 357
Ford starter relays are externially grounded and it sounds like you have lost that ground. You can check it by running a ground wire from the relay to a good ground on the car. Then try to start
it. If the ground is good it should start.
Old 05-20-2004, 08:50 AM
sharpe 1's Avatar
Ford starter relays are externally grounded and it sounds like you have lost that ground. You can check it by running a ground wire from the relay to a good ground on the car. Then try to start
