SUPPORT OUR SPONSOR
  #21 (permalink)
Old 10-30-2004, 02:24 PM
Bob In Ct's Avatar
Cobra Make, Engine: SPF - 351W, 944 non-turbo
Mr. Pink:
This is the thread.
Bob
  #22 (permalink)
Old 10-31-2004, 06:02 AM
Cobra Make, Engine: Backdraft # 91, Black w/White stripes and Red Rookie's, 302 w/AFR 185's.
Bob.....you were right....just had 2 new BF T/A's put on the front..only had 1500 miles on old ones....both new at no cost...120 mph is smooth as silk. Sears tire shop also bought a new aluminum wheel...tire idiot bent one when breaking the bead. I agree with your original advice....even the rag joint won't solve the problem....tires are the problem......period.
  #23 (permalink)
Old 11-01-2004, 05:58 AM
TButtrick's Avatar
Mr.Pink,
I've chased the same problem for two years. I've changed much if not all suspension parts. I've had three sets of tires on the car, two sets of BFGs and lastly a set of Yokos. I've had the tires/wheels dynamically balanced, statically balanced and road force balanced on a Hunter at Moroso's speed shop. None of which cured the problem. I've had anywhere from 15-25 ounces of weights on my wheels and every time they seem like they get put in different locations. I've had the weights installed on the inside and outside of the rim. I've had the wheels trued round within .001" then reinstalled the tires, balanced again and STILL no luck. I've checked the wheels ON the car to confirm that the rotors/wheels are true.
I put my car on jack stands and put it in gear and let it idle while I checked the OD of the tire. My vibration in fact came from the tires. You can see the videos here and here
The ONLY thing that I've found that cured my problem was having the tires shaved. Bob in CT found a place that will shave the tires even if they've been on the road. I only had the fronts done and 90% of the vibration is gone. I went from needing 20 ounces on one tire to needing only 1 ounce. I was so happy that I never took the time to take the rears to have done as I've been enjoying the car much more. I'll take them to have them done this winter.
Some tires may be better than others but most fat 15" inchers have the potential to cause problems as our cars are so light. A dampener will help but your masking the problem. My thinking was that if F1 cars can get by without a vibration, why shouldn't mine? They run a solid link steering as well so why don't they have a problem? Yes, our cars feel every little bump and given the same tire on a 3500 pound car, you probably wouldn't even notice it. Any amount of bump-steer will amplify the problem so make certain you've got that under control as well.
My $.02 worth
  #24 (permalink)
Old 11-01-2004, 10:12 AM
Big-Foot's Avatar
Cobra Make, Engine: RCR GT40 #45
Todd - You oughta lift up one of those F1 tires sometime... 4 of them will weigh less than one of your front tires..
Of course 4 of those F1 tires will also cost about the same as a full-boogey set of CNC ported AFR heads!
Regards - Randy
RCR40 #45 http://www.GT-Forty.com
  #25 (permalink)
Old 11-01-2004, 11:11 AM
Cobra Make, Engine: spf 408W 500HP by PE
I've got an SPF with 15" wheels. Car has Yokohama Avids on it and I don't get any noticeable vibration at any speed. I know the previous owner had B.F. Goodrich on it and replaced them with the Yoko's. Car only had 1200 miles on it when I bought it, so there must have been some issue with the BFG's.
Rick
Display Modes
HTML code is On
