Old 06-14-2004, 12:52 AM
ALF's Avatar
ALF ALF is offline
Question 289FIA wheel from Trigo
Hello
I'm interest to change the wheels on my car. Now I'm interest to go with the 289FIA wheels from Trigo.
Before I'll order it, I need the size of the wheels and the adapters to be sure they fit on my Cobra!!
Has anyone experience with this wheel and could send me the size information I need?
Thanks.
ALF
Old 06-14-2004, 09:45 PM
G.R.'s Avatar
Send a message via Yahoo to G.R.
Trigo FIA wheels are 7 1/2'' wide front and 9 1/2'' wide rear--they have 3 1/2'' offset(D on your image) adapters fit 4 1/2"(ford) 4 3/4''(GM), plus 5 and 5 1/2'' bolt patterns, order accordingly for your particular bolt pattern. The adapters will add aprox. 3/4''--another words your new Trigo wheel will sit 3/4'' further outboard than the current bolt on wheel, usually not a problem unless you have a solid rear axle then you "may" encounter the wheel and tire doesn't fit inside the fender lip quite right.
Hope this helps--Trigo is very easy to work with and if you can give them a call they can and will go out of their way to make sure that you get the correct wheels and adapters. I know it might be difficult calling them from Europe.
Old 06-19-2004, 11:17 PM
Rick Parker's Avatar
Forgive me but I believe item "B" in you diagram is your negative offset value. The adapters add .375 increase in track width per side.
Old 06-20-2004, 07:22 PM
G.R.'s Avatar
oops item B--me fingers don't type so good
