SUPPORT OUR SPONSOR
Old 06-15-2004, 10:15 PM
joea's Avatar
Cobra Make, Engine: ERA #676, 428SCJ (2x4), TKOII
Question clutch install
I'm getting ready to install the clutch on my 428 FE. I read a mustang article that mentions 3 alignment dowels that insert into the flywheel to center the clutch pressure plate. ( I'm NOT referring to the clutch discc alignment tool) I don't have these dowels...are they used on an FE flywheel?
"There are 10 types of people out there....the ones that understand binary and the zeros that don't."
Old 06-16-2004, 05:06 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Three 5/16, very long, with a flat blade screwdriver slot in the top dowels that are installed at 120 degrees apart into the flywheel to align the pressure plate while putting the clutch together... type dowels??
Haven't heard of them.
If they are the same ones I used a very long time ago, take three 3" 5/16 bolts ( I think they are 5/16 ) bolts and cut off the heads ( or just leave them on ), cut a slot in the top of each to remove them after the clutch assembly has been secured to the engine.
Hope this helps.
Old 06-16-2004, 08:18 AM
joea's Avatar
Sounds like they are not a required part...I think the pressure plate bolts only line up one way.
HTML code is On
