SUPPORT OUR SPONSOR
Old 06-26-2004, 10:48 PM
347's Avatar
347 347 is offline
Cobra Make, Engine: .
Default Trick flow
I am dumping my webers and coverting to efi.
You guys running 347's or 351's, what manifold,size throttle body,size injectors,ecu,heads,cam are you running?What sort of power are you making?
I am planning to run a trickflow R manifold,90mm throttle body,36/40lb injectors and a haltec E6X ecu,Engine is a 347, 10.2 comp,ported windsor snr's,285cfm @.560, solid flat cam 248@.050, .560 lift, 110 lobes,1 3/4 headers, 4.1 diff and tremmec
Any suggestions/comments on my thoughts?
HTML code is On
