Old 07-25-2004, 07:06 AM
S_Beaudry's Avatar
Cobra Make, Engine: (building) - Hunter #74 w/ 302 small block (320hp under the hood). . . how many wires are there in a wiring harness?
Send a message via AIM to S_Beaudry
Default 460ci Oil Sensor . . . Where?
Call me inexperienced, but just help me.......
Where is the location that the oil sensor/oil pressure gauge screws into on the block?
Can't seem to find a threaded hole anywhere for it to go.
Please help . . . .
I'm not busy because I did it right the third time . . .I think!
Old 07-25-2004, 08:49 AM
KrAzEcJ's Avatar
Cobra Make, Engine: Unique# 4279459
Send a message via ICQ to KrAzEcJ
Just in case you missed the other post...
Old 07-25-2004, 09:04 AM
S_Beaudry's Avatar
Wow, illustrations, can't go wrong that way!
Old 07-25-2004, 09:27 AM
KrAzEcJ's Avatar
I noticed in your pic you are using the stock heads. Are you planning on going with some after market aluminum heads or are you planning to stay stock? I am running the 429 CJ heads on my 460 so I could have the studs for roller rockers instead of the bolts but I know of some places that make a conversion kit for your heads if you did want use them still and use roller rockers also.
Unique # 4279459
Old 07-25-2004, 05:48 PM
S_Beaudry's Avatar
I am thinking I am going to stay pretty well stock on this, as little money as possible.
After I finish building the car and get it road worthy, I will probally start building the real keeper big block for her.
Probally go with a 427 and really spend money on it, the 460ci is the test/fit/run/size/noise engine for now.
