Old 08-14-2004, 01:51 PM
Cobra Make, Engine: Shell Valley, 351 Sportsman
Default Dash Grommets
I'm looking for grommets that are located under the screws for mouting the dash. All of the Home Depot, Menards and Ace Hardware stores carry the stamped steel units, which look like they would cut into the dash fabric once you snug them up.
Does anyone have a source for solid units that would have a flat back?
Old 08-14-2004, 02:18 PM
G.R.'s Avatar
Send a message via Yahoo to G.R.
I used s/s finish washers and screws--the trick is to not use a powerdriver to run the screws in but to do it the old-fashioned way with a screwdriver so you can control the pressure--just run the screws in until they start to snug down and the washer doesn't spin--all the screws do is hold the dash in place, there is little stress on it so they don't have to be snugged down super tight. If you use a power driver you do run the risk of cutting the fabric or leather with the washer, unless you can control the driver speed and torque.
I've not seen any nice finish type washers with any flat back though there are rubber and plastic types available but they look more utilitarion(sp).
Old 08-14-2004, 05:53 PM
Bud Man's Avatar
Cobra Make, Engine: Former Owner/Builder of KMP142 427 Sideoiler, Tunnel Wedge, Aluminum heads, etc.
Motorsports International carries solid brass chrome plated dash escutcheons as original. For authenticity, use nothing else.
Call Marge Guentzler at 619 390 9080.
Bud
Old 08-14-2004, 06:59 PM
I used the SS finish washers and glued them to a flat SS washer that was just slightly larger .that way I had the area of the flatwasher against the fabric.
Mike H
Old 08-14-2004, 07:34 PM
Bud & Mike,
Thanks for the lead and suggestions.
