February 2026
Old 08-19-2004, 01:54 PM
Question Differential Fluid?
Just wondering what kind (brand name) and weight and how much of differential fluid everyone else is useing in there 9 inch ford 31 spline (narrowed about 9 and a half inches) rearend differentials?
http://66cobra.0catch.com
Old 09-03-2004, 05:26 PM
The best diif fluid is probably the synthetic stuff. I use Mobil 1 gear lube, something like 75w-90. Redline makes a synthetic gear lube as with some other companies. Even though it is for use in limited slip diff's, I was starting to get some clunking, so I had to add some of the limited diff additive as well.
You fill it up to the level of the fill plug, half way up the diff housing.
Old 09-11-2004, 09:17 PM
Mobile 1 synthetic diff oil with a bottle of Ford friction modifier added for the posi. Fill to the bottom of the fill plug.
Old 09-11-2004, 10:25 PM
SCOBRAC's Avatar
Mobile 1 or other good synthetic for an open differential. FYI I used it in my 20k mile salisbury and it made noise. I now use 90wt Valvoline designed for posi / powr loc units.
michael
Old 09-13-2004, 08:12 AM
BMK's Avatar
BMK BMK is offline
Yes use the Valvoline also. A small ratchet fits nicely in the drain plug to assist with removal. Front drivers/left side Don't overfill.
Bernie
Bernie Knight
