SUPPORT OUR SPONSOR
Old 08-19-2004, 12:54 PM
Question Differential Fluid?
Just wondering what kind (brand name) and weight and how much of differential fluid everyone else is useing in there 9 inch ford 31 spline (narrowed about 9 and a half inches) rearend differentials?
http://66cobra.0catch.com
Old 09-03-2004, 04:26 PM
Cobra Make, Engine: CSX4000, 427
The best diif fluid is probably the synthetic stuff. I use Mobil 1 gear lube, something like 75w-90. Redline makes a synthetic gear lube as with some other companies. Even though it is for use in limited slip diff's, I was starting to get some clunking, so I had to add some of the limited diff additive as well.
You fill it up to the level of the fill plug, half way up the diff housing.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
Old 09-11-2004, 08:17 PM
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Mobile 1 synthetic diff oil with a bottle of Ford friction modifier added for the posi. Fill to the bottom of the fill plug.
Old 09-11-2004, 09:25 PM
SCOBRAC's Avatar
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
Mobile 1 or other good synthetic for an open differential. FYI I used it in my 20k mile salisbury and it made noise. I now use 90wt Valvoline designed for posi / powr loc units.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
Old 09-13-2004, 07:12 AM
BMK's Avatar
BMK BMK is offline
Yes use the Valvoline also. A small ratchet fits nicely in the drain plug to assist with removal. Front drivers/left side Don't overfill.
Bernie
Bernie Knight
HTML code is On
