Old 11-04-2004, 10:53 AM
jams's Avatar
Cobra Make, Engine: B & B
Default Install Ferrules??
Hi,
I am installing ferrules for my soft top but I don't know how they get fastened to the car body. The type I have does not use a nut. Right now they are just sitting in the hole I drilled.
Any suggestions?
Old 11-04-2004, 12:13 PM
DonC's Avatar
Jim:
ERA uses a snap ring on the bottom of the ferrule to keep it in place. Easy on, easy off.
DonC
Old 11-04-2004, 12:33 PM
GeorgiaSnake's Avatar
Cobra Make, Engine: Sold - Unique FIA - SA 396 Stroker
Jim a picture or two would help.
Randy
Sold the Unique - Bought a Porsche TT - Sold the TT - Bought a truck
Old 11-04-2004, 12:57 PM
jams's Avatar
It is hard to tell from the picture but the ferrules have fine groves. They are not threads.
Old 11-04-2004, 07:00 PM
G.R.'s Avatar
Send a message via Yahoo to G.R.
Drill the hole slightly smaller, coat the ferrule or hole with slicone, the gently drive the ferrule in, the grooves on the ferrule wii grip the side of the hole, the silicone helps bond the ferrule.
I can't remember what size hole I drilled but I used a micrometer on the ferrule to determine its size then used a drill bit one size smaller. Taped the hole to protect the paint,drilled the hole then with a bit of care and a judicious use of a white rubber mallet I drove the ferrules home through the 'glas.
Old 11-04-2004, 10:36 PM
HI Cobra's Avatar
Anyone:
Where can I get the ferrules like those in the pictures?
Right now I just have holes in the glass and I think they
would be a major improvement.
Thanks.
Flip
Old 11-05-2004, 05:04 AM
jams's Avatar
Thanks for your answer.
Visit the site below for the ferrules. Look under soft top accessories. It will upgrade your look!
http://www.cobraaccessories.com/catalog/
Old 11-05-2004, 05:28 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Jams, If you already have the holes drilled and they are not going to be able to grip the sides as Gary described, I understand Gorrilla glue will hold them in place.
Careful, this stuff sticks and is messy, but it holds very well.
Just a thought.
