Old 01-03-2005, 10:09 AM
Cobra Make, Engine: 2004,FFR 302, carb. motor
Default Voltage too high?
I have a Powermaster 60 amp one wire alternator and the volt gauge reads 16 volts. When I turn the fan on it drops to 15. Is this too much? I don't want to blow the battery. I drove around yesterday (temp in Georgia 75) for over an hour and everything was fine. Am I worrying for nothing?
Old 01-03-2005, 10:39 AM
HighPlainsDrifter's Avatar
Arrow Meter
Hi,
I would buy/borrow a real digital meter and measure the voltage. The gauges are notorious for being wrong. I run the same PM alt, it is set at 14.4 volts. One volt up or down will be ok, higher voltages may overcharge the battery ,boil it.
Perry.
Old 01-03-2005, 10:45 AM
SCOBRAC's Avatar
The alternator is internally regulated. The battery will tell the internal regulator what it needs. 16 seems pretty high. Is it a 12 volt alternator? Are you sure it's a 12 volt battery? (some are not) You might put a voltage meter on the battery to see what you are actually getting back there.
michael
Old 01-03-2005, 10:51 AM
SCOBRAC's Avatar
http://store.summitracing.com/defaul...6+volt+battery
michael
Old 01-03-2005, 12:06 PM
I beleive you . My volt gauge started out not showing anything .Then I compared it to new gauges at the dealer .Mine regestered more than they did. Battery charger went a little nuts and my voltgauge started working. Shows 14V untill I turn fans or lites on.
Mike H
