SUPPORT OUR SPONSOR
Old 01-09-2005, 09:07 PM
EarlsflyinCobra's Avatar
Ouch Ouch Hot Sand
Cobra Make, Engine: Street Beasts w/302 Twin Turbocharged....Under Construction!!
Send a message via AIM to EarlsflyinCobra
Default Gasket matching???
Someone splain this to me please?? I get the drift of why, but , do you buy the gaskets and make the holes match the flow areas or do you take the heads/intake models and order specific gaskets??? Any assistance would be greatly appreciated!!!!!!!
Safe Flyin, errrrr Drivin, Earl
Old 01-10-2005, 03:11 AM
427 S/O's Avatar
Earl, I believe most folks match the heads to the gaskets (if that's what your asking), I use a die grinder with sandpaper wheels.
Perry
Old 01-10-2005, 05:24 AM
Hotfingrs's Avatar
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
If you buy aftermarket heads, they are usually matched to a certain gasket, then you match your intake to the same gasket. For instance, the AFR heads I have were matched to a Fel-Pro 1206 gasket, I then had the intake matched to that gasket.
Jack
XSSIVE .....
HTML code is On
