SUPPORT OUR SPONSOR
Old 02-06-2005, 11:59 AM
Russ Dickey's Avatar
Cobra Make, Engine: Unique Motorcars 289 FIA
Default Battery Questions
Recently, my car has been requiring a jump-start to get it going for a drive. When I take it out for a cruise, it performs fine. All the electrical stuff and headlights work as normal. But if I shut it off....it's dead. It won't restart again. My amp gauge doesn't work, but I assume the alternator is fine since the headlights work ok.
So the other night I put the battery charger on it, and after about 30 minutes I come out to check on it, and it sounds like bacon is sizzling on a griddle. I think "this can't be good", so I immediately turn off the charger, and start thinking that maybe it's a dead cell in the battery (which is only a year old, but it is an Advance Auto parts "special"). I get in the trunk and start to take out the battery, which sits inside of a marine-style plastic case, and notice that there is a bunch of water sitting at the bottom of the case!
Now granted, I don't have the cover on top of the case, so the top of the battery is exposed, but I can't figure out how water could get down in there. I checked everything inside the fenderwell to see if there was any way that water could get down in there when I washed the car, or could be splashed up in there when I've (rarely) driven it in the rain or through a puddle. And from what I can see, there is no way that water could be getting in there.
So can you guys provide any insight? Do batteries "sweat"? Are standard wet-cell batteries prone to leaking? Does the battery sound like it is the root of my problem, or could it be something else?
Thanks to all,
Russ
HTML code is On
