Old 03-07-2005, 03:10 PM
Default I have a coilover question.....
I need a compressed length of 10.25" and an extended length of 13.25".
Could I get enough height adjustment to obtain that with a 9.75"/14.625" shock?
If I used a 10" spring with either one, I should get about the same ride height....if I compressed the spring to the same point....right?
Old 03-07-2005, 04:49 PM
Anyone, anyone?
Old 03-07-2005, 05:19 PM
Bly,
Don't understand your question.
Old 03-07-2005, 05:32 PM
Basically Shell Valley recommends a shock with a compressed length of 10.25 and an extended length of 13.25.
So what would happen if I used a shock with a longer extended length, but used the same length spring?
Would the car sit higher, or would the longer shock have enough adjustment to let the car sit at the same height as the shorter shock?
Old 03-07-2005, 05:41 PM
Default Coil Overs
blykins,
Years ago I was looking for similar information. Check out this manufacturer's site for a wealth of information. They make Aldan Shocks and coilovers, among other things. I suggest this site for information only, and am not steering you toward their product line.
www.magnumforceracing.com
click on Aldan Eagle Coil Overs for some information.
Go back to the prior page and click on Coil Over Shock Springs for additional information.
Old 03-07-2005, 06:02 PM
I just think I'm confused on how everything works....I understand with the first scenario (10.25/13.25) there's a 3" stroke. On the second scenario (9.75/14.625) there's almost a 5" stroke.
Having said that, the second shock is also approximately 1-3/8" longer at extended length.
However, both specs recommend a 10" spring.
So here's my question (I think): If both shocks had a 10" spring placed on them, and then both shocks were adjusted so that each spring was 9" long (for example).....then the second shock would still be an 1 and 3/8" longer than the first....right? So the car would sit (in this case the front) roughly an inch higher in the front with the longer shocks. Do I have this right so far?
So given that the second shock is still over an inch longer, could the ride height still be manipulated so that the shocks are equal length?
Old 03-07-2005, 06:21 PM
Cobra Make, Engine: shellvalley 428 ford
blykins: you need to know the distance between mounting points at ride height. when you know that then you can determine your shock requirements. go to speedwaymotors.com. they have a great shock chart in their coil over section. Example: ride height=10-3/4 to 11-3/4 needs a shock that will compress to9-1/2and extend to 12-3/4. if I did not help, sorry.
Byron W.
Old 03-07-2005, 06:27 PM
You're being very helpful. However, I have the requirements from SV on what shock lengths I need.....I was just trying to see what the difference is between different sizes.....if I could use a longer shock, and if so, what the visual differences would be.
Old 03-07-2005, 07:11 PM
blykins: if you look at speedway, i think you would find enough adjustability in the next longer shock. if you could use the 12 inch
spring you could use a softer shock maybe. the speedway chart helped me a lot. also, Dana at shell valley no doubt could answer your question. good luck. post what you decide.
Byron w
Old 03-07-2005, 07:36 PM
Richard Hudgins's Avatar
blykins,
The damper lenght that you are speaking of will be fine.
So will the 10 inch springs.
Ride height is not determined by the stroke lenght, it is determined by the compression of the spring.
The coilovers will have enough threads to get your ride height correct.
Just make sure that you are using the correct spring rate.
Best regards,
Richard Hudgins
Old 03-08-2005, 03:55 AM
Default Thanks
Thanks for the replies...
I knew you guys would have an answer as soon as I could get my thoughts out in actual words that could be understood.
I was wanting to go with a little longer shock so that I could get a little squat in the rearend if I want.....but have adjustability to also get it down on the ground if I want....
Thanks for the help guys.
Old 03-08-2005, 04:03 AM
Hey Byron.....I searched and never could find that chart you're speaking of.....could you post a link please?
Old 03-08-2005, 04:09 AM
If there is a possibility of binding, use some kind of a limiting strap so that your suspension doesn't drop past the original specs. In the front, you could break a ball joint. In the back, you may have driveshaft binding.
Old 03-08-2005, 05:39 AM
Cobra Make, Engine: Several
Very proper points, Strictly
Spoken like a true drag-racer.
"A free people ought not only to be armed and disciplined but they should have sufficient arms and ammunition to maintain a status of independence from any who might attempt to abuse them, which would include their own government."
George Washington
Old 03-08-2005, 05:50 AM
good morning blykins, post a fax number and i will fax the chart to you. i cant figure out how to post a link. not that computator smart, sorry
byron
Old 03-08-2005, 06:00 AM
It's easy Byron....just pull up the website.....and when you're looking at the page that contains what you want, just highlight the address with your mouse in the address bar at the top of the browser. Then hold the control button in, and press C.
Next, just reply to this thread.....and when you start typing the message, just hold the control button in, and press V.
That will copy and paste the link from your browser into a message box like this.
Old 03-08-2005, 05:35 PM
blykins, the web site does not have the chart like the catalog does but here is the of two qa 1 shocks. if you have a fax i will fax the entire chart.
byron w
721395-200 QA1 COILOVER KIT, 200 LB.
PR $369.95
721395-300 QA1 COILOVER KIT, 300 LB.
PR $369.95
721395-325 QA1 COILOVER KIT, 325 LB.
PR $369.95
721395-375 QA1 COILOVER KIT, 375 LB.
PR $369.95
721395-400 QA1 COILOVER KIT, 400 LB.
PR $369.95
721395-500 QA1 COILOVER KIT, 500 LB.
PR $369.95
7213955 SHOCK & COILOVER KIT ONLY - NO SPRING
10 3/4" - 11 1/4" @ ride height. 12 3/4" ext. 9 1/2" comp. Uses 8" spring.
EA $154.95
SUGGESTIONS
25508-200 CARRERA SPRING 8" COILOVER, 200 LB.
EA $49.95
25508-300 CARRERA SPRING 8" COILOVER, 300 LB.
EA $49.95
25508-325 CARRERA SPRING 8" COILOVER, 325 LB.
EA $49.95
25508-375 CARRERA SPRING 8" COILOVER, 375 LB.
EA $49.95
25508-400 CARRERA SPRING 8" COILOVER, 400 LB.
EA $49.95
25508-500 CARRERA SPRING 8" COILOVER, 500 LB.
EA $49.95
721485-115 QA1 COILOVER KIT, 115 LB.
PR $369.95
721485-140 QA1 COILOVER KIT, 140 LB.
PR $369.95
721485-185 QA1 COILOVER KIT, 185 LB.
PR $369.95
721485-225 QA1 COILOVER KIT, 225 LB.
PR $369.95
721485-300 QA1 COILOVER KIT, 300 LB.
PR $369.95
721485-450 QA1 COILOVER KIT, 450 LB.
PR $369.95
7214855 SHOCK & COILOVER KIT ONLY - NO SPRING
11 3/4" - 12 1/4" @ ride height. 14" ext. 10 1/8" comp. Uses 10" spring.
EA $154.95
Website is:
www.speedwaymotors.com
Old 03-08-2005, 06:06 PM
Lots of thanks Byron
