Old 04-06-2005, 04:51 PM
S_Beaudry's Avatar
Cobra Make, Engine: (building) - Hunter #74 w/ 302 small block (320hp under the hood). . . how many wires are there in a wiring harness?
Send a message via AIM to S_Beaudry
Default '87 302ci heads . . . Need Help!
What size are the holes for the bolts that hold on the exhaust on the heads?
Seems to be metric thread, want to be sure, someone......
I'm not busy because I did it right the third time . . .I think!
Old 04-06-2005, 05:53 PM
DavidWard's Avatar
Cobra Make, Engine: FFR 1204 With Stack Injection
Send a message via ICQ to DavidWard
They should be 3/8 x 16.
http://members3.clubphoto.com/david251117/guest-1.phtml
Old 04-06-2005, 07:07 PM
S_Beaudry's Avatar
3/8 x 16 only went in about 1 or 2 threads before they stopped turning.
Tried a couple different holes but the same result.
Do not have any metric on hand to try.......
Old 04-06-2005, 07:15 PM
Rick Parker's Avatar
See if a 3/8 NC tap will go in without a lot of effort. Maybe there is corrosion in the threads.
Old 04-06-2005, 07:25 PM
Cobra Make, Engine: BDR 302 AFR 165
Default head bolts
I believe a 7/16 diameter head bolts on late 302's and 1/2 diameter bolts on 351 heads. I think you will need a busshing for the 7/16 bolts. I got mine from ARP.
later Dennis
Old 04-07-2005, 02:34 PM
S_Beaudry's Avatar
A 3/8" course tap seems to go thru with "pressure" on it....
Can these threaded holes get "warped" some how?
Old 04-12-2005, 05:35 AM
sharpe 1's Avatar
Cobra Make, Engine: Midstates,SBF 357
most likely corrosion from the bolts that were in there before.
