Old 04-29-2005, 12:05 PM
EarlsflyinCobra's Avatar
Ouch Ouch Hot Sand
Send a message via AIM to EarlsflyinCobra
Default Will these work?????
9.5" x 17" wheels by P. S Engineering, 5" backspace
Will these work, adding adapters of course, on the Ford Mustang rear end used in my Cobra build, or will the spacing be off???
Thanks, Earl
Old 04-29-2005, 12:19 PM
What's the rearend length?
Old 04-29-2005, 12:25 PM
Ouch Ouch Hot Sand
I'll have to check but I think it is 51 1/2" for some reason....Earl
Old 05-01-2005, 08:29 PM
Ouch Ouch Hot Sand
My hub width is 59 1/2" and my build book says wheels with "standard" offset, what ever that is.
Now can someone tell me if these will work or not????
PLEASE...................
Old 05-02-2005, 06:16 PM
351-EM's Avatar
Cobra Make, Engine: Everrett-Morrison Cobra, 427W T-5 Z tranny
Earl,
I am assuming that your using a solid axle 9" or 8.8" rear right? I just went through a fiasco with my Everett-Morrison Cobra as I tried to put a 52 1/2" hub to hub 9" rear in my chassis and use the standard Trigo wheels (3 1/2" b.s.). No way Jose! I ended up having to sell the rear Trigo's for dirt and order a set of custom 6" backspace rears from Phil @ PSE Wheels. If you have have a 59+" rear hub to hub, you may be in for a very rough time. You can also check the width of the body at the rear wheel arches, but I am willing to bet you can't make them fit without either narrowing the rear or locating an earlier rear that is short from the factory (1955-1959 9" are 52 1/2"). Please let me know if you have any additional questions, I hope to prevent others from feeling the pain I have been through the last 6 months.
Later,
Chris
