SUPPORT OUR SPONSOR
Old 05-07-2005, 05:14 AM
Default MSD... fuse ?
I have a 6AL MSD . When I recently re did my dash , I hooked up my SW tach wrong . My tack and shift light stopped working after the wiring correction . I will check the MSD monday for a pulse on the tack output , I was wondering is there a fuse in the MSD ?
Old 05-07-2005, 05:25 AM
Yetiman's Avatar
Cobra Make, Engine: Arntz/SBC/Jag
Yes, it has at least an internal fuse for the whole unit, not sure if there's another one for the tach output though.
We come into this world naked, screaming, and covered in blood. With dedication and a little planning, you can go out the same way.
View my overflow Gallery (much more to come !)
Old 05-07-2005, 06:15 PM
Thanks , the car runs so it is not the main one . I let you know what happened .
Old 05-09-2005, 03:21 AM
I started the car and put a volt meter on the tack out put . Got voltage , but did not seem to change much . I think it is suppost to be a sqare wave . I took the cover off , did not see a fuse inside .
Old 05-09-2005, 03:37 AM
This problem started when I had the dash out and hooked the tack wires wrong , I put the pos on the sig , and the sig on the pos . Thought I fried the tack as I asked around . Got a new tack , hooked it up right , did not help .
Does anyone know what to look for comming from the tack out ?
Old 05-09-2005, 05:20 AM
Ron61's Avatar
Post
John,
Iamnot that familiar with the MSD tack output, but if it is a square wave you would need a scope to really verify if it is the proper amplitude and strength. Possibly you could have damages something in the output to the tac trigger in the MSD unit, but as I said I am not very familiar with those units. If you have a friend with one, see if he will let you try your meter on his output and look for any difference in what you see.
Also, and I did this once when I thought my tach had gone south, I took it out and just used clip cords and hooked it to my Comet's little 289 with the stock ignition. It worked perfect there so I traced the problem down to a connector in my signal lead that had worked loose inside the crimp style connector.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 05-09-2005, 11:29 AM
DonC's Avatar
Cobra Make, Engine: ERA #684, 428 FE, TKO600
MSD is generally pretty good at helping out with this type of thing. Call or email their tech support.
Dons
Old 05-09-2005, 05:48 PM
With a volt meter , msd said 2 or 3 volts . I got a new msd , all works fine . My mistake = $ 370
On the bright side , I will send out the old and have a good spare
Old 05-11-2005, 07:58 AM
Cobra Make, Engine: SPF 974
John...........MSD Tech line is 915-855-7123. Also, any wiring schematics/troubleshoot guides you may need to refer to will be available on their website .
Display Modes
HTML code is On
