SUPPORT OUR SPONSOR
February 2026
Old 05-18-2005, 03:49 PM
wtm442's Avatar
Beam Me Up Scottie
Default Removing Bumperettes
Help
I've tried every kind of 3/4" wrench and cannot remove bumperettes. Tried standard an short closed end, deep offset closed end and crow's foot. Does anyone make a special tool? If not, I'll have to bend up a few different wrenches because a box end will not go over the nut on some because the bumperettes are moved to one side and the bumperette interferes with the wrench.
Help!
Warren
Warren
Old 05-18-2005, 04:09 PM
xlr8or's Avatar
Try unbolting from the other end and remove the whole thing from the car first. Can you get to the nut on the end of the post?
Old 05-18-2005, 05:09 PM
wtm442's Avatar
Beam Me Up Scottie
Even if I could unbolt the struts inside the engine compartment and pull out the whole thing, I'd still have the same problem. The body is not a problem.
I cannot find a wrench that will fit onto the nut.
Thanks
Warren
Warren
HTML code is On
