SUPPORT OUR SPONSOR
December 2025
Old 05-19-2005, 08:48 PM
Cobra Make, Engine: 408w 500 h.p. 550 ft.lbs
Question hydraulic throw out bearings
Which manufacturer has the most reliable HTO for use with a Toploader with a lakewood shield?????????
Old 05-19-2005, 09:32 PM
Cobra Make, Engine: 427SC Unique
Mcleod!!!!!!!!!!!!!
Ask for Red or Les.
Good luck,
Brent
Old 05-19-2005, 09:48 PM
Cobrabill's Avatar
Cobra Make, Engine: Superformance 427 Side-Oiler
McLeod
Brent-ya forgot about George.
The rest of the world can have their opinion about the United States just as soon as WE give it to them.
Old 05-19-2005, 10:24 PM
Cobra Make, Engine: I drive and test my customers
We have had nothing but trouble with the McLeod. And yes we had pedal stops on the four units that failed! I just installed a Tilton in John Touts. aluminum Superformance Cobra ,and it has been working great. It has no banjo fittings to leak, and it bolts into the bellhousing, not on the candle stick (throw out bearing slide on the front of the trans.) like the McLoud. You can check the operation of the unit before you install the transmission. I will use this type from now on. Call me if you need a part number.(513) 738-5001. Hope this helps.
Eric H.@ Performance Engineering
Old 05-19-2005, 11:34 PM
Cobrabill's Avatar
And my McLeod unit has never failed WITHOUT a pedal stop.The banjo fittings have been up-graded also.
Old 05-20-2005, 04:45 AM
cbnus Have you looked into Keisler thrownout bearing? They are at www.keislerauto.com. There is no bleeding needed to be done on this setup. Titlon is the other, You also need to have a pedal stop in your car or you will over extend it and have problems. Make sure that the supply line is bolted down or that will get pulled into the clutch assembly and ripped up. Rick Lake
Old 05-20-2005, 06:07 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Yes, I believe the single most important thing on a HTOB is a positive stop on the pedal.
I put a positive stop on my setup and I do not use a HTOB.
Old 05-20-2005, 08:17 AM
Roscoe's Avatar
I've got a Tilton bearing with over 23k miles on it. Also, Lakewood housing, centerforce dual friction clutch and tremec 3550.
Never had a problem.
Roscoe
Roscoe
Display Modes
HTML code is On
