SUPPORT OUR SPONSOR
Old 06-06-2005, 07:26 AM
DougD's Avatar
Cobra Make, Engine: Sold my beloved Shelby CSX 4068, Gessford 427 Ford
Default mini starter wiring
I have a Bosch mini starter to put on my 5.0. It has a solenoid mounted on it a la GM cars. My car has a separate fender-mounted starter solenoid as per most vintage Fords. The Bosch has a large pole on the solenoid where I assume the battery cable goes (from the fender-mounted solenoid). It also has a small spade type connection that I assume is to engage the starter. My question is how do I wire this up? Do I have to make a jumper somehow? If so, where to connect it, and how heavy should the jumper wire be?
The starter is made to fit this car, and came with no instructions.
CSX4068, '69 Bronco, '70 BOSS 302, '87 Mustang GT, '08 Roush Trak Pak
Old 06-06-2005, 10:26 AM
zipzip's Avatar
Cobra Make, Engine: Midstates work in progress, personally built 302
I bought a mini-starter, and here is the instructions I received with it. It sounds similar to what you are describing. Hope this helps.
You might be a redneck if you think the National Anthem ends with "...Gentlemen, start your engines."
Old 06-07-2005, 05:20 AM
DougD's Avatar
zipzip
Perfect! Just what I need. Thanks!
Doug
HTML code is On
