SUPPORT OUR SPONSOR
February 2026
Old 06-19-2005, 02:32 PM
Cobra Make, Engine: ERA
Default brake light not working
happy fathers day all.
my brake lights are not working, i checked fuses, wiring hook up at rear tail lights..
any common problems anyone has experienced?
i guess my next move is to check master cylinder wires..
thanks in advance.. ken
Old 06-19-2005, 03:10 PM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Where is the brake switch???
Find it and short the two wires. You should hear a click and the lights should come on.
If you short the wires and the lights do not come on, look for the relay. If they do come on, you need a new switch.
Hope this helps!
Old 06-19-2005, 03:52 PM
ERA brake light switch
Old 06-19-2005, 07:53 PM
thanks for the help.. will attempt to get new switch.
Old 06-19-2005, 10:25 PM
daltondavid's Avatar
Cobra Make, Engine: 1967 GT 350 #2264
My slide on Connector was loose and just required a snugging from pliers to fix that issue once!
www.saacforum.com
Old 06-20-2005, 01:02 AM
ill check that too, thanks dalton/david.. what connecter, at the master cylinder, or tail lights? i checked both, is there a relay somewhere?
Old 06-20-2005, 06:02 AM
Cobra Make, Engine: Look-a-like cobra POS
It may be a pressure operated switch, might have to be adjusted or replaced.
Bret.
B. Ewing
HTML code is On
