February 2026
06-23-2005, 10:52 AM
Ouch Ouch Hot Sand
Fuel Injection Question
I am having a clearance problem with one of my fuel rails hitting the distributor. There does not seem to be a way to get a fitting in the end of the fuel rail for the return line.
I am feeding the fuel rails from the rear fittings which are easily accessible.
My question is this;
If I plug the fuel rail and just take the return line from the other fuel rail is this going to cause an "imbalance" in the system?
06-23-2005, 04:19 PM
As far as the fuel pressure goes, if both rails are connected, it shouldn't make a significant difference where your return line bleeds off. You will lose a bit of the lower temperature associated with recirculating fuel though, which may present a problem with a hot-soak condition.
06-24-2005, 03:48 PM
Ouch Ouch Hot Sand
Okay, my local speed shop guru is telling me I need a feed and return line to each fuel rail or a feed to one, acrossover to the other and a return from that one, for the system to work properly. I ma soooooooooooooooooooooooooooo confused, can someone show me the way out???????????????????
I know, I know, somebody is going to ask, "which way did you come in"?
That was meant to be a comical note on the citeation!!!!!
06-24-2005, 04:01 PM
Cobra Make, Engine: CSX4815
This is from the TWM Induction website. Check out the link below.
http://www.twminduction.com/faq/faq-FR.html
06-24-2005, 05:05 PM
OR
Earl:
Try this link and go down to the bottom of the page for illustrations of various supply and return setups.
http://www.verycoolparts.com/programming.htm
DonC
06-24-2005, 06:09 PM
Ouch Ouch Hot Sand
Thanks all.....this really helps....>Earl
07-11-2005, 04:17 PM
MA
Cobra Make, Engine: Shopping at the moment.
If you can read this, thank a teacher. If it is in English, thank a soldier. If it is in ebonics thank your senator.
Learn Ebonics here.
07-12-2005, 04:52 AM
Ouch Ouch Hot Sand
Thanks Hankcar and Chrispy.....the problem is not the height but the girth.....as all men have, ha-ha.......hankcar, the one you suggested does not have the computer module hook up for the 5.0, I checked....and Chrispy, the one you suggested is the one I have......I thought I had it figured out using the option B;
but another member tells me this is not a good idea................
07-12-2005, 05:36 AM
MA
Earl,
I think option C would be ideal. As mentioned above you will have fuel recirculating, thus a cooler fuel.
The other methad I have seen used is to loop a piece of braided hose around the dist. Straight shot out of each rail.
BTW wich injection do you have? I assume the fuel rails are on the inside?????
Chris
Learn Ebonics here.
