SUPPORT OUR SPONSOR
Old 06-29-2005, 07:42 PM
HSSS427's Avatar
Cobra Make, Engine: ERA #414 427 s/o w. Shelby Aluminum heads, Edelbrock Performer RPM Intake, Mighty Demon 750, Tremec TKO 600
Default Kirky race seat install tips
Just bought a Kirky race seat and would like to swap it in when I go to the track. I also have some seat adjusters on the way from Breeze Automotive. Before I dive in I wanted to throw a post out and see if anyone had any tips on doing this. Any clearance issues? What angle is better to mount it at - 20 deg or 10 deg?
Appreciate any tips!
Thanks!
Scott
Old 06-29-2005, 08:44 PM
DAVID GAGNARD's Avatar
Scott;
While my car is a 65 Mustang,it should not be much different.........I also use a Kirkey alum. high back racing seat,I prefer about a 10 degree or less layback,I like my seat sitting more upright than most,suggest you try many different setting to see what is the most comfortable for you..........I also prefer to bolt my seat in and not use any seat adjusters,just set it for yourself and forget about it...........One old time driver gave me this tidbit,temparerly mount your seat,get in it and fully buckle up,stretch out your arms/hands to the top of the steering wheel,your wrists just be on the top and your hands kinda hang over the edge towards the windshield,all assuming you can reach the pedals,adjust from there.............
2 other hints,if you are going to spend any amount of time in a racing seat,add more padding to it,they are not very well padded and are not that comfy,I went to Wal Mart and bought some of that egg-crate looking foam and cut it out to the seat,added one layer to the back and sides and 2 layers to the bottom........................also use top grade bolts with big washers/lock washers/ and those nuts with the plastic do-hicky in them,so they do not fibrate lose...........................
David
DAVID GAGNARD
Old 06-30-2005, 06:44 PM
HSSS427's Avatar
Default Thanks David
Seems the main tip is to play with it and try it in different positions before committing drill to metal. I'm waiting on the tracks to arrive and then can have a look to see what options present themselves. Since I'm on the street more than the track, I'm trying to figure out a way to swap the original looking seat in and out with the Kirky, and am also hoping to get a removable roll bar built for use at the track as well. Like someone told me - sooner or later I'm probably going to have to make a choice between street and track and stop trying to swap back and forth.
Thanks!
Scott
HTML code is On
