Old 07-04-2005, 07:02 AM
S_Beaudry's Avatar
Cobra Make, Engine: (building) - Hunter #74 w/ 302 small block (320hp under the hood). . . how many wires are there in a wiring harness?
Send a message via AIM to S_Beaudry
Default Headlight wiring question...
What is the simplest way to wire in the headlights in a Cobra?
Where does the headlight relay fit in, and what else is needed to complete the system?
Never wired from scratch before, so go easy on me....
I'm not busy because I did it right the third time . . .I think!
Old 07-04-2005, 07:13 AM
Ron61's Avatar
Post
Many of the kits have a relay mount that holds 4 relays. Mine is on the drivers side kind up out of sight on the sidewall. Hard to get to as old as I am so when a relay went bad for my lights, I just went to NAPA and got a two relay mounting and put it on the passenger side where I could get to it easy and it is still out of sight. There are several schematics on the club showing how to do the high and low beams from the relay. The 2nd relay I got is just a spare. There should be a fuse for your low and one one for your high beams.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
