Old 07-05-2005, 02:17 PM
Default Glasurit paint
I had an old can of crystal white Glasurit paint ,it said" Glasadure Urithane Accrylic "with a large "21"I have since used that quantity up. I've had problems trying to get Sherwin Williams brand to match.It keeps coming up gray when compared to my original paint.I did find a supplier of Glasurit paint ,but they don't mix any .The body shop they refered me to did base coat clear coat only.Is there a body shop, paint store ,etc that sells and mixes Glasurit 22 single stage urithane accrylic paint in user quantiyies .In the Tacoma Wa area? anywhere?
Mike H
Old 07-05-2005, 02:42 PM
Is base coat clear coat that much of an advantage over single stage ? I've tried using the scanning gun and the paint code on the can .I've actually received three pint cans of product with the purchase of the first pint can. a less expensive grade came up gray then they gave me more white to dilute it. I added the white pigment, Better.Then they mixed and gave me a can of what I'd call cream.I did't really even try that batch of paint.Then I left my hood for examination and scanning and that ended up being a pint can of the better stuff,That paint seemed as gray as the first can of paint after I had mixed in the extra white.
So now I go to my local body shop that also has a Sherwin-William mixing bench.Problem is he only does base coat clear coat paint. Then I go to the Body shop that uses the Glasurit brand,They also only do the base coat clear coat paint. I understand formula 21 isn't around anymore I know they make 22 now, a single stage urithane accrylic paint . Wher can I get some?
Mike H
