Old 07-07-2005, 01:00 PM
Cobra Make, Engine: Kirkham 427
Send a message via AIM to jpfletch1 Send a message via Yahoo to jpfletch1
Default side pipe mounting
Sould side pipes be mounted with some sort of rubber between the mount and the frame or are they mouned directly to the frame? It seem like the vibration may crack someting if it is not dampened with something. Thanks
Old 07-07-2005, 01:30 PM
Cobra Make, Engine: sold BDR #123 351w, Tko 17" full polished wheels
Backdraft uses a rubber insulator between the frame bracket and the side pipe bracket.
Old 07-08-2005, 07:26 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
I use three manifold gaskets to separate the flange from the frame. The dang flange gets hot and the rubber one I tried melted first time out.
You can make the gaskets by cutting three discs about 2" in diameter and drilling a hole through the center. Do this per side, 6 discs total. Paint them black or what ever.
Hope this helps.
Old 07-08-2005, 07:34 AM
computerworks's Avatar
...moved the rogue post to "CSX4502 for sale"
...moving this thread from For Sale forum to Shop Talk forum
ClubCobra Moderator
