SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 08-04-2005, 08:18 PM
Cobra Make, Engine: 408w 500 h.p. 550 ft.lbs
Question MSD Ignition
I supplied a MSD 6a box to my builder which he wired into the harness. Now after starting the engine He was not able to shut it off. Now he tells me there is a inline oneway resistor missing that allows the ignition to shut down.
Is this true??? Does anyone know a # for same or a description & is it normally included with the ign. box & someone lost it.
Thanks
Craig
Note:
Pro Billett distributor, 408W
Old 08-04-2005, 08:55 PM
G.R.'s Avatar
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Read the installation instruction manual included with the unit. There is some mention of possibly needing a resistor, Chrysler unit? if memory serves me...not a supplied part from MSD
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
Old 08-04-2005, 09:11 PM
TonyMadrid's Avatar
Cobra Make, Engine: A&C 351W, C4
Default MSD Ignition resistor
If you're using a point distributor you need to use a ballast resistor.
Other then that I've not heard of an inline resistor.
I suggest a call to MSD tech Support, they are very helpful and should be able to provide you with the skinny for your application.
Old 08-04-2005, 10:41 PM
Rick Parker's Avatar
I think he is refering to is a diode that is sometimes installed in the charging circuit. In some installations there is enough current that continues to backfeed into the ignition system while the alternator is still spinning after the key is switched off. The MSD box takes very little current to trigger it consequently it continues to run with the key in the off position.
This should help
Rick
http://www.msdignition.com/1troub1.htm#runon
Rick
Old 08-05-2005, 07:06 PM
Thanks Rick,
I spoke to MSD Tech Dept today & they pretty much told me what was covered in the site you sent.
Thanks much for taking the time to help.
Next problem is---
I am using a top loader with a 8.8 rear end with a 3.2something gear. 295/50/r15 yokohama's.
Question????
What speedo gear do I need-- # of teeth???
Thanks
Craig
Old 08-08-2005, 12:38 PM
sharpe 1's Avatar
Cobra Make, Engine: Midstates,SBF 357
Call david kee toploaders.He can tell you which geer to run.
Old 08-08-2005, 02:53 PM
scootter's Avatar
Cobra Make, Engine: SPF #1436 514
I tried the diode trick on my car, and it did not help. When you look at the site for MSD, it will tell you which wire to take of the voltage regulator to try it. Alot of guys are using something they put on the carb.
HTML code is On
